Sagan Technology Metro • View topic - FR: Rhythm Explorer 1-8 Keycommand Support
Postby Lytz1 » Thu Aug 03, 2017 7:01 pm
Wouldn't it be a good idea to enable the numerical keys 1-8 to switch the rhythm explorer patterns
when the RE window is open? This would be especially helpful when recording various patterns
into the arrangement. Also would reduce a lot of mouse-clicking...
The Rev.Arp already takes over some keys, so I thought it might be a good idea if the RE does that as well.
(Also it might be worth a thought to have some sort of "quantize pattern start to next beat/bar"-option
so that when we switch from i.e. pattern 2 to 3, pattern 3 starts to play right on the next beat or bar, no matter how bad
the manual timing is.)
Re: FR: Rhythm Explorer 1-8 Keycommand Support
Postby Jerm » Fri Aug 04, 2017 12:00 am
Yes those are good ideas.
Postby Jerm » Tue Aug 08, 2017 12:04 pm
keys '1' - '8' will select the RE pattern when there are generated patterns and '0' will select the original pattern. This is working in the latest beta. I am still thinking about the quantize idea.
Postby Lytz1 » Tue Aug 08, 2017 3:42 pm
Awesome. Probably might contact you for a shot at the beta.
Postby Jerm » Tue Aug 08, 2017 4:18 pm
I believe the beta is available (for the Mac.. Full version only) right now.
