Sagan Technology Metro • View topic - The effects window - what's on and what's off?
Change the buttons in the effects window?
yes
2
100%
no
0
No votes
Total votes : 2
Postby Scoot » Fri Apr 25, 2003 5:27 pm
Currently the power light is green, the bypass light is red when on, and the new reverb button is dark grey or light grey.
Would it be possible to keep the main power light green, rename the "bypass" to something like "effect on/off" and make it green and the reverb button green when on?
This would make more sense...........when its green it's on! :wink:
Postby Jerm » Fri Apr 25, 2003 6:11 pm
Scooterman,
If you draw the pictures of the buttons in all desired states, and they look good, I will implement them in, at least, the new 'scooter' style.
:wink:
Note that the reverb button is a system control. It will look different in OS 9 than it does in OS X.
Postby Scoot » Sat Apr 26, 2003 2:48 am
I thought the effect button is on a OSX only plug-in?
Perhaps a polling forum could be set up and a poll of the members here to see if they're happy with the functioning of the on and off effects.
Maybe I'm the only odd ball and noone else would want to change. :shock:
Postby Jerm » Sat Apr 26, 2003 3:03 am
Yes. You are right. The Reverb button is OS X only.
Postby Scoot » Sat Apr 26, 2003 4:58 am
I promise to only vote once! :lol:
