Sagan Technology Metro • View topic - Modulation Editing
Modulation Editing
Modulation Editing
Postby fastlanephil » Fri May 23, 2014 9:56 pm
Hello Jeremy,
When I'm editing modulation in Controller:Modulation mode and am using the pencil tool, if I want to move the play point to listen to a note or whatever I have to select the arrow tool from the tool pallet so I don't draw in modulation while clicking around. Would there be a not too difficult way to set up a key command to temporarily disable the pencil tool function so the pencil tool only works like the arrow tool while that key is being held down.
Phil
Re: Modulation Editing
Postby Jerm » Sat May 24, 2014 1:11 am
Phil,
If, when you want to start playback at a designed spot, you clicked in the bar header, either on the black or between the tics of the header, then you will not need to switch tools at all. Note that this will select an even measure or a beat of a measure.
Postby fastlanephil » Sat May 24, 2014 9:49 am
Yes, I see how this works now. :D
Thanks Jeremy!
