Sagan Technology Metro • View topic - Track & Graphic window coordination
Postby srosenberg » Tue Oct 22, 2013 10:02 pm
When only one track is displayed in the graphic editor, it would be helpful if it were the same track currently highlighted in the track window. When a different track is selected in the track window, the track displayed in the Graphic editor is not updated to reflect that change, unless multiple track windows are open there.
srosenberg
Re: Track & Graphic window coordination
Postby Jerm » Tue Oct 22, 2013 11:08 pm
I think all you need to do is check 'Sync track selection in graphic editor' from the preferences dialog as shown below. Then click Ok or Save.
Alternatively you can double click on the track in the tracks window to select it in a new pane of the graphic editor.
