Sagan Technology Metro • View topic - Column right/left shortcut
Postby srosenberg » Fri Sep 26, 2008 11:09 am
It would be good to have a key shortcut for duplicating the effect of the right and left scroll arrows from the keyboard, using option page up/down as an alternative to the larger movement of page up/down
srosenberg
Postby Jerm » Fri Sep 26, 2008 11:16 am
Have you tried using '<' and '>' ?
Shortcuts
Postby srosenberg » Fri Sep 26, 2008 6:26 pm
Thanks for the tip. Is there a complete list of shortcuts integrated into Metro?
srosenberg
