Sagan Technology Metro • View topic - arrow + shift selections (and other oddities)
Postby al » Fri Sep 07, 2007 8:42 pm
I have suggestions that are about mouseless operations on the graphic editor. No mouse is involved here. Shortcuts for the graphic editor make sense for the most part, except for a few things here and there.
I'm not sure why the graphic editor can't add (or subtract) to a selection while pressing the shift key like in most mac applications.
In MacOS itself, to increase a selection of files in a finder window, you'd press the shift key while increasing the selection with the up-arrow arrow keys. In metro you could use the left-right arrow. Maybe up/down arrows as well, for forceps editing mode (vertical selections).
This would apply to ANY operation that involves navigating inside the graphic editor.
For example, if I'm navigating on a per note basis with the bracket keys [ ]. I should be able to also add the shift key modifier to add selection as I navigate a note a time.
There are some other small things that I'm trying to understand why they work the way they do. They just feel counter-intuitive, and I don't know where else to post them. Below are suggestions on pre-existing commands I feel aren't consistent. These aren't feature requests.
If I select a note, and I'm able to drag it forwards and backwards with the arrow key. Why then do I have to press the command modifier key and the up/down arrow to shift the key a note up/down?
Why not keep the arrow tools for selection, and nudging of selected notes. Then use the command modifier + up/down arrow keys to in/decrease velocity, and cmnd left-right arrow to in/decrease duration.
I emailed you 4 video screen captures to better illustrate this. They're under 100k a video (h264).
btw. one video is a suggestion for a deselect key (the esc key). because currently you can't deselect a selection unless you use a mouse.
oh. it would help if users were able to post screenshots of their metro windows right on the forum. I'm not talking about img hosted by the user, but by sagan's forum webserver.
al
Re: arrow + shift selections (and other oddities)
Postby Jerm » Tue Sep 11, 2007 11:10 am
al wrote:This would apply to ANY operation that involves navigating inside the graphic editor.
Yes. Good suggestion. This will be added.
al wrote:If I select a note, and I'm able to drag it forwards and backwards with the arrow key. Why then do I have to press the command modifier key and the up/down arrow to shift the key a note up/down?
Because it has been determined that a user is far more likely to be modifying velocity information than pitch information.
al wrote:Why not keep the arrow tools for selection, and nudging of selected notes. Then use the command modifier + up/down arrow keys to in/decrease velocity, and cmnd left-right arrow to in/decrease duration.
Yes a way to modify duration with the keyboard is definitely desirable!
al wrote:btw. one video is a suggestion for a deselect key (the esc key). because currently you can't deselect a selection unless you use a mouse.
Yes another good suggestion. I just have to make sure that ESC is not used for something else. I know it is used to cancel out of long operations.
al wrote: it would help if users were able to post screenshots of their metro windows right on the forum. I'm not talking about img hosted by the user, but by sagan's forum webserver.
This probably isn't going to happen. Doing so would likely increase spam all over our site.
