[phpBB Debug] PHP Notice: in file /viewtopic.php on line 988: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. [phpBB Debug] PHP Notice: in file /viewtopic.php on line 988: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4505: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4507: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4508: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4509: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) Sagan Technology Metro • View topic - playing AIFF files with my keyboard
With a plug-in sampler that support those formats. I do not know of a sampler that supports MP3 but it is easy to convert Mp3 to aif. There are many sampler plug-ins out there (e.g. Sampletank 2, VSamp, etc.)
I use VSamp - it's cheap, stable, and easy on the processor. It can use AIFF files natively - to use MP3s, convert them to AIFF files in iTunes. If for some reason you must create a soundfont file, your options are limited. The only one I know of for OSX is PolyPhontics:
Yes, it reads .wav, .aiff, and sdII formats. You can also load soundfonts (but not create them). It is very easy to map samples accross the keyboard and you can layer samples for velocity switching, etc. Not bad for $39. You can read more about it at:
