Paul wrote:When I'm using a native plugin, there's no latency but when I use a plugin from one of these two cards there is
If you mix the audio to a new track, view the two tracks as panes in the graphic editor and zoom in all the way, is there an offset in the audio that you can see? If yes, how many samples is it?
Paul wrote:The strange thing is that I don't have this latency problem with Logic Pro. I can insert a UAD and a Powercore plugin on the same channel and there's still no latency.
If you reduce the audio-packet size and do the same test with mixing, what is the sample offset?
