Sagan Technology Metro • View topic - Art Vista Grand Piano
Postby fastlanephil » Fri Aug 05, 2005 12:22 am
I recently purchased the Virtual Grand Piano from Art Vista(Hans Adamson). It's on sale for $99 until 8/16/05 then it goes up $21. If you are looking for a piano that is better than what comes with a sound library then check this one out. It sounds really great and comes with enough variations that you'll find the sound you are looking for. It's a joy just to play.
It does require a G5 Mac(NI's Kontakt Player) and uses about 6GB of hard drive space. It can be used as a stand alone or a plug-in. It seems to work fine with Metro 6.3.
Postby fastlanephil » Tue Aug 30, 2005 11:04 pm
It looks like a DP 1.25 GHZ Mac will also work fine with this piano from a user post on Northern Sounds. The developer admitted he was told by NI to set the minimum Mac as a G5.
