Sagan Technology Metro • View topic - Filterscape
Filterscape
Filterscape
Postby Jazzdude » Fri Feb 04, 2005 11:18 am
Nice new synth from u-he:
http://www.filterscape.com/
Check it out!
Jazzdude
Postby Jazzdude » Sat Feb 05, 2005 8:11 am
I should add that Filterscape is a parametric equalizer, virtual analog filter, delay effect, and modulation device. When you download it, you get a sister plug-in called Filterscape VA, which is the virtual analog synth, and Filterscape Q6, a 6 band equalizer with dynamic capabilities.
Jazzdude
Postby Jerm » Sat Feb 05, 2005 10:28 am
HIghly recommended!
