Sagan Technology Metro • View topic - SampleTank Dirt in Tracks overview
Postby fastlanephil » Mon Dec 27, 2004 1:58 am
I'm getting some noise with ST2's French Horn and it is showing up as what looks like dirt or something brown in the tracks overview window. I just discovered what that weird window does-it saves you a lot of work. I assume the brown stuff is audio noise that Metro is detecting from the sample. I tried the French Horn by itself in a new file and without reverb but I'm still getting a soft crackle but the brown stuff isn't in the tracks overview window. I guess this must be a sampling loop noise. Does anyone else hear this with the French Horn in ST2. Will SoundSoap2 remove this noise though it's probably a good utility to have anyway for a final mix.
Postby Jerm » Mon Dec 27, 2004 1:39 pm
The brown is probably some controllers. Look in the event window and the time that the brown stuff occurs to see exactly what it is.
Postby fastlanephil » Mon Dec 27, 2004 11:23 pm
Your right, it's modulation for some reason. It's also in the piano track as sustain. I'm not sure why the F horn is dirty but i'll play with it. It's also makes my Clavinova speakers rattle if I have it up too loud. I can always use GPO for that instrument. GPO may come in handy yet but for what i'm doing ST2 is a much better tool and the string sections from Sonic Reality's Symphony Strings expansion tank sound better than GPO's also.
Audio Buffers
Postby fastlanephil » Mon Jan 10, 2005 1:37 am
We'll, I have spent a few hair pulling hours trying to find the reason for the clicks in the tracks. I can't wait for the audio buffer packet size to be where it bites me on the nose so i'll remember to up it for play back. :roll:
Postby Jerm » Mon Jan 10, 2005 1:40 am
Yes, it should be easier to change.
