Sagan Technology Metro • View topic - Anyone know how to use SupaTrigga in Metro?
Postby rlwilliams » Fri Nov 05, 2004 3:23 pm
I can't get the VST version, or AU version to do anything. Any suggestions?
rlwilliams
Postby Scoot » Fri Nov 05, 2004 5:53 pm
does this bring anything to the problem?
The plugin requires "advanced timing info" supplied by the VST host to work properly.
Postby Scoot » Fri Nov 05, 2004 6:13 pm
I've got the AU version working.....it's a bit of a laugh. :lol:
I imported a midi file and solo'ed the drums.
Installed a soundfont through the DLSMusicDevice plugin and then placed the trig under it.
Starting it playing
Then you can just turn the knobs and hear all sorts of weird and wild things.
It doesn't work with quicktime sounds.
I guess I am using a midi track and the soundfont to play audio samples....so this use of supatrigga probably works in plugins like idrum and sampletank etc.
