Where are those .sf2 files supposed to be stored ?
Should they be stored in one of those OS Panther/Jaguar ~Library/Audio/ folders ?
If so which folder ?
{I use both cats ( on different drives of course ).}
Scoot wrote:It doesn't matter where you stick soundfonts on your drive.
Scoot wrote:
You grab the DLSMusicDevice from the plugins window and when installed you view it in the effects window and click on the 'none' button to load a soundfont into it. Use the open dialog box to locate the soundfont you want to use.
Allocate outputs to the DLSMusicDevice from the setup menu and then change your midi tracks from internal to DLS to hear the difference.
w wrote:Well that clears that up for me Scoot.
I wonder if it would work with Band-in-a-Box OS X or do you have any thoughts / ideas on how to use SoundFonts with Band in a Box?
At the moment I use Apple'sQT rather then my keyboards sound generators.
