Sagan Technology Metro • View topic - Awesome!!! AU Speed Plugin
Postby Scoot » Mon Apr 05, 2004 6:16 pm
Similar to an OS9 EXPENSIVE audiosuite plugin called Speed.
Download this plugin from http://airy.andre.online.fr/AU/index.html
It's at the top with the line:
04/04/04 : Speedster MusikMesse 2004 Preview is here. More (docs...) on this later !
It states its a preview (I don't know if that means it's unfinished or going commerical), but it's great in metro. :D
- open an audio track
- throw the plugin on an aux
and hit play and adjust the controls.
I had to stop and start to hear the results.
OR use it as an offline effect.
happy tickering.
this thing is amazing
Postby Jerm » Tue Apr 06, 2004 12:52 am
Yes. Very nice. Make sure you import some audio and then in the mixer window turn the audio fader all the way down and then in the aux page turn the aux fader all the way up and set it to pre instead of post.
Postby Scoot » Sat May 01, 2004 8:44 am
Updated
- latency compensation
- better timestretch quality (no more out-of-tune modulation)
- slighty less CPU use
- text fields are now much easier to edit (type 'return' to validate)
- automation bug correction
http://airy.andre.online.fr/AU/index.html#speedster
