Sagan Technology Metro • View topic - Aux questions
Aux questions
Aux questions
Postby jonrandall » Mon May 19, 2003 6:41 pm
[REMOVED BY AUTHOR]
jonrandall
Removing Aux Effects
Postby Jerm » Mon May 19, 2003 7:18 pm
Remove effects from the effects window. Click on the name of the effect in the effect window and use edit/clear or the backspace key.
Postby jonrandall » Mon May 19, 2003 8:29 pm
[REMOVED BY AUTHOR]
jonrandall
Postby Jerm » Mon May 19, 2003 8:48 pm
jonrandall wrote:Why is it required to click directly on the name, and do you have any idea how the names could get "virtually" selected in some instances?
You can have multiple effects in this window. Click on the name to select it or drag it to rearrange the order of effects. Obviously you need a way to just clear certain effects.
jonrandall wrote: Then I noticed that, with no effect at all in the window, the "Clear" option was still available in the "Edit" menu. I found that curious in light of what you said. So I selected it. Metro unexpectedly quit.
This bug will be fixed in 6.0.7.2. Thanks.
Postby Jerm » Mon May 19, 2003 8:59 pm
Jerm wrote:
jonrandall wrote: Metro unexpectedly quit.
This bug is fixed in 6.0.7.2
Postby Scoot » Mon May 19, 2003 8:59 pm
When you drag an effect across to the effect window, its name is selected. If you drag another one across, the first plugin name is still selected. I guess perhaps the second plugin name should now be selected......it might make more sense.......or metro is assuming you want to remove the first plugin? :D
If you click somewhere else, you deselect the name. Then there is no way can you go back and have a name selected unless you click on it and get teh clear back.
Having clear available with no plugins is probably a bug.
Yes I made it unexpectly quit too!
Then again........I am normally controlling plug ins from the window not the blimmin menus.
Postby jonrandall » Tue May 20, 2003 3:47 am
[REMOVED BY AUTHOR]
jonrandall
Postby jonrandall » Tue May 20, 2003 4:00 am
[REMOVED BY AUTHOR]
jonrandall
Postby Jerm » Tue May 20, 2003 10:23 am
I should point out, jonrandall, that clicking on the effect name to select it, is not secret at all.
This page, the main effects page, accessed by pressing command-shift-/ or command-? (same keys) from the effects window itself, explains exactly how to select effects:
http://www.sagantech.biz/metro/help/hel ... ging-49575
This page explains exactly how to remove an effect:
http://www.sagantech.biz/metro/help/Met01065.htm
