Sagan Technology Metro • View topic - MidiKeys
MidiKeys
MidiKeys
Postby lesag002 » Thu May 01, 2003 2:38 pm
Anyone using MidiKeys (I think it by Creed, IIRC) as a soft controller? I can get a signal in the tracks window (the meter shows a signal) from it but I don't get any sound output? The Metro keyboard works fine with the QT synth, soundfonts, and SampleTank, but Midikeys isn't working with any of them.
Mark LeSage
Twin Cities, MN
lesag002
Postby Jerm » Thu May 01, 2003 3:09 pm
Make sure you turn MIDI thru on.
