Sagan Technology Metro • View topic - Metro 7 Windows Stylus rmx
Postby mark scheel » Fri Feb 12, 2016 4:28 am
Hello,
i cannot open my stylus vst, i am on windows 7. the plugin is working in other DAWs on the system.
when i try to open it Metro say : no proxy dll found.
Kontatk is opening fine.
Stylus has no standalone Version, its only usable as a plug in.
may someone can help me out?
cheers
Mark
mark scheel
Re: Metro 7 Windows Stylus rmx
Postby mark scheel » Fri Feb 12, 2016 4:43 am
ha
i found the answer, i had the wrong vst version in my vst folder,
it needed to be the 64bit version.
now it works.
maybe this is helpful for someone else
cheers mark
mark scheel
