Sagan Technology Metro • View topic - Audio Units and V2 Audio Units
Postby Scoot » Thu Apr 24, 2003 6:27 am
I assume V2 is a newer version. As Metro shows them both and I guess they do the same thing, can you remove one?
Postby Jerm » Thu Apr 24, 2003 7:20 am
Yes. V2 are the new effects. I think they were created in OS 10.2. 10.1.5 only supports v1 audiounits.
I suppose in the next version I will eliminate them from the plug-ins window when running 10.2 or greater.
