Sagan Technology Metro • View topic - Kontakt 5
Kontakt 5
Kontakt 5
Postby fastlanephil » Tue Feb 19, 2013 4:58 pm
Hi Jeremy,
There are three versions of Kontakt 5 available in the Plug-Ins Window. Kontakt 5, Kontakt 5 8-Out and Kontakt 5 16-Out. Would you know what if any difference there is between them as far as using them in Metro 7.01 and if one version preferable. They do all seem to basically work in Metro 7.01
Phil
Re: Kontakt 5
Postby Jerm » Tue Feb 19, 2013 7:12 pm
They are all the same except for the number of outputs. The 8 and 16 denote the number of outputs. I think the regular kontakt has 24. If you are using less than 8 outputs within kontakt, it makes sense to use the one with the 8 in the name.
