Hi Jeremy,
I'm using Garritan Instant Orchestra in Aria on an aux bus and placed on a track. If I load one of the multi-instrument ensembles it plays fine unless I press too hard on the Axion 49 and trigger aftertouch. Then the ensemble quits playing unless I trigger aftertouch. There is a control knob in Aria that says LPass(cc25) that goes to zero when I trigger aftertouch and then goes from zero on up when I trigger aftertouch again. If I reset the LPass(cc25) control knob then it works normally again until I trigger aftertouch again.
I don't encounter this problem when I'm using the Aria player with Garritan Instant Orchestra in stand-alone mode.
Is there a way to get around this?
I can also just use my piano keyboard to prevent .
Phil
