Sagan Technology Metro • View topic - VST to Audio Unit Wrapper - Why?
Postby Scoot » Sun Apr 20, 2003 6:21 pm
Apart from having the VST plugins work system wide (which I don't need anyway), why would you do this?
Are they going to take less CPU or would they just run the same as they do under VST?
If this would allow you to run OS9 plugs then that would be cool. :lol:
Postby Jerm » Sun Apr 20, 2003 9:26 pm
No. The purpose for this is to get a program that no longer supports VST (e.g. Apples-> Logic) to run VST plug-ins.
Postby Scoot » Mon Apr 21, 2003 1:20 am
Ahhhh I think I can guess why such a 'seperate' company like emagic would want to do that! :wink: :wink: :wink:
posting
Postby Naveed123 » Fri Jun 07, 2013 2:34 am
this is very very nice and going to take less CPU or would they just run the same as they do under VST?
Naveed123
Re: VST to Audio Unit Wrapper - Why?
Postby Jerm » Fri Jun 07, 2013 3:01 am
I don't really understand your question here.
The wrapper is so the programmer has less code to write as it makes one plug-in format similar to another.
