Sagan Technology Metro • View topic - An audio unit drum sampler
Postby Scoot » Wed Apr 16, 2003 10:48 pm
Can be found at http://www.manyetas.com/ritmo.html
Beta expires May 15th and full version will be $25.
Have no idea how it works. Downloading it myself now. Is just over a meg. I am not endorsing it........just thought Metro users might want to have a look.
Features
Audio Unit plug-in format
24 instruments per instance
Flexible sample playback engine
Multiple outputs
Multimode filter
Envelope generator
Tempo-syncable delay for each instrument
32-bit internal processing
Have fun
Scoot.
Postby simon201 » Sun Apr 20, 2003 10:26 pm
Loads ok into an aux channel. Can't seem to hear any sounds. Crashes Metro when I try press play?. Other (free/demo) Vsti's work fine in Metro 6.
simon201
Postby Scoot » Mon Apr 21, 2003 1:31 am
I loaded it into an instrument track instead of the aux bus. Works fine.
Also loaded the 2 click sounds and the drum loop that came with metro and they can be heard by clicking on the piano on the left in the graphic editor when you hit the correct piano key.
Then you can pencil in the notes and then play them and they work just fine.
Enjoy.
