I think the real problem is understanding how outputs work in Kontakt. I just can't get my head around it. When I instantiate Kontakt (VST version), I see one stereo output and four aux channels.
When I add a channel ('Add channel') and then press Conf. at the bottom of the channel strip I've just added, I get to see a list with two channels with their physical outs on --not connected--. I then click on the --not connected-- bit and a pop-up with available outputs (so it seems) appears. In my case: Kt.St.1(1) and (2), Kt.Aux1(1) and (2), Kt.Aux2 and Kt.Aux3. I really have no idea which one to take...
I guess the bottom line is: how do I set this up in Kontakt?
Of course I know this is in fact a question regarding Kontakt but seeing as how you've been able to get it to work...
Also, I don't know which version of Kontakt to choose. I see three VST versions in the Plug-ins window: Kontakt 3, Kontakt 3 8 out, Kontakt 3 16 out. With each version I still only get to see one stereo output and four aux channels. Is there a particular one I should take or will any one of those do just fine?
If you could shed some light on the matter, then that would be great.
