Sagan Technology Metro • View topic - 10.4.9 problem?
10.4.9 problem?
10.4.9 problem?
Postby almapercus » Tue Apr 03, 2007 6:53 pm
Robert
almapercus
Postby Jerm » Tue Apr 03, 2007 11:44 pm
This is only a problem for Logic Users. Metro does not use the Apple program AUVal for anything. However, if a plug-in will not load into Logic (meaning it fails AUValidation) there may be problems with it. Failing AU validation is an indication that the plug-in is not abiding by standard AU procedures and protocols.
I have heard that OS 10.4.9 screws up some plug-ins that use the PACE copy protection scheme though.
