I just installed Sampletank 2.2 using a G4 with MOTU 828mkII and Metro 6.3.8.4 when I use the stand alone app Sampletank works great and sounds great. When I load it as a plug-in in Metro the sound is awful and the octaves are too high. The samples are very weak sounding compared to when it's played on the Sampletank app. This is when I load it as Music Device VS dragged into the effects/synth window. The VST OSX version gives me the error "too many outputs. plug-in cannot be loaded."
Did I miss something in the set up? I've only used hardware samplers and this is my first experience with a software sampler. I got sampletank because it was recommended here and the MOTU 828 interface so I can use the multi outputs for outboard processing of the sampler instruments.
