Sagan Technology Metro • View topic - Aphex Aural Exciter
Aphex Aural Exciter
Aphex Aural Exciter
Postby jukehouse » Sun Feb 05, 2006 2:49 pm
I'm wondering if the Aphex Aural Exciter, which is a TDM plugin, will work in Metro.
If not, is there anything equivilant available that will work in Metro ?
jukehouse
Postby Jerm » Sun Feb 05, 2006 5:30 pm
As far as I know (and it is not much) TDM plug-ins only work with Digidesign Pro Tools.
I don't know too many exciters available on the market. Izotope has Ozone 3, which they call an Analog Modeling Plug-In. It has a nice multi-band exciter built-in.
You could also try searching kvr.
Postby Jerm » Sun Feb 05, 2006 5:32 pm
Also there is greenoak excitifier which is free.
Postby Scoot » Mon Feb 06, 2006 4:24 am
There's 2 camps. TDM and everyone else. :wink:
TDM for the DSP and hardware cards and then digi also has RTAS plugins requiring the computer's CPU to do the work (budget LE version you'd find with a digi 001 interface for instance).
Would assume metro could run RTAS versions but it's all very proprietary.
Hopefully the greenoak is close?
Postby MP » Mon Feb 06, 2006 9:00 am
Metro currently supports AU and VST formats. RTAS plugins would not work.
Mike
MP
Postby Scoot » Mon Feb 06, 2006 1:03 pm
MP wrote:Metro currently supports AU and VST formats
And I think audiosuite if you can still find them.
MP wrote:RTAS plugins would not work.Mike
Correct but if digi stopped having such a closed system, the RTAS version would be the one to work with Metro.
Personally I would think the TDM and RTAS developers have a short life expectancy unless they bring their tools to VST, AU and other PC equilvalents.
