Sagan Technology Metro • View topic - Virtual instruments with multiple outputs
Postby Jerm » Mon Oct 03, 2005 8:54 am
Paul wrote:In that case, doesn't Metro support Kontakt 2? What problems do you think it might give?
Like I mentioned previously, Kontakt 1.5 had a problem whereby the plug-in would not re-load. Once it was loaded and unloaded the next attempt to load it would return an error. I do not have Kontakt 2, so if you can save off your Metro document with Kontakt 2 tracks and reload it then there may not be any problems. I would love to hear that this is indeed the case.
Previous
