Sagan Technology Metro • View topic - 2 movies? and mpegs
2 movies? and mpegs
Topics related to Video
2 movies? and mpegs
Postby Scoot » Mon Mar 07, 2005 5:27 pm
Is there a way to see 2 movies at once....or is there only 1 movie window available?
Bringing a movie into Metro splits the video and audio onto seperate tracks..........and you can see the audio levels in the mixer.
Bringing in a mpeg you don't get the split, you can hear the audio but there are no levels in the mixer. Is this cause it's unsupported?
Postby Jerm » Mon Mar 07, 2005 7:55 pm
You cannot view more than one movie at a time with Metro.
This is because Quicktime does give the application access to the interleaved audio and video data from an MPeg video. Your best bet is to no edit using MPeg. Only output to it as a last step.
Postby MP » Sat Jul 08, 2006 12:29 pm
Remember, when you edit a video file that was compressed using a lossy video codec (where data is removed to reduce file size), you degrade the quality again by re-compressing it during export. It's always best to work with the cleanest, least compressed video when editing.
Mike
MP
Return to Video
