Sagan Technology Metro • View topic - metro 7 windows no video support
Topics related to Video
Postby mark scheel » Fri Feb 12, 2016 4:45 am
hello,
i m on windows 7 with the latest metro version,
i can t get a video into the program.
is this not supported yet or am i am missing something?
cheers
mark
mark scheel
Re: metro 7 windows no video support
Postby Jerm » Fri Feb 12, 2016 5:41 pm
Video is supported only through Quicktime. Quicktime is available on Windows only in the 32 bit version. This is because that is only version Apple has made available.
Postby mark scheel » Sat Feb 13, 2016 10:07 am
hi jeremy
thank you for the fast reply
i am not shure what it means. i have downloaded quicktime for windows installed it. when i try the import movie option
nothing happens.
If i drag the movie onto the timeline i get an error -4 unimplemented core routine
i tried a *.mov *.avi *.mp4
no difference.
any ideas?
greetings mark
mark scheel
Postby Jerm » Sat Feb 13, 2016 12:38 pm
When you install Metro you need to select the 32 bit installer. Then you need to be sure to run the 32 bit installed version and NOT the 64 bit version. If you installed the 32 bit version it will most likely be stored in C:\Program Files (x86)\Metro where 'C:' is your installation drive.
Postby adriane.masson » Tue Dec 27, 2016 6:06 am
Hi Jerm, as I saw this post, I want to get the occasion to ask my question, because I’m in the same case. I’ve also downloaded the quicktime 32 bits version in my Windows 7 but when I try to import the movie, nothing happens for me either. So, any ideas or are we really missing something? Thanks in advance.
adriane.masson
Postby Jerm » Tue Dec 27, 2016 8:08 pm
What is the file type of the movie you are trying to import? Are you sure you are running the 32 bit version of Metro?
Return to Video
