Sagan Technology Metro • View topic - Insert/delete blank time in Metro SE?
Postby RichieM » Wed May 18, 2005 1:04 pm
Does Metro SE let you insert and or delete arbitrary amounts of blank time in MIDI tracks? If yes, can you do all tracks at once, or is it in individual tracks only?
Thanks in advance for any help you can give me.
RichieM
Postby Scoot » Wed May 18, 2005 3:26 pm
I have MetroSE 6.25 Demo here.
It does do it.
Open a midi document.
Open the tracks window and drag an area across the bar numbers.
Then choose insert time from the EDIT menu.
Postby RichieM » Wed May 18, 2005 5:41 pm
Thanks, Scoot. I downloaded the demo and played a while and discovered what you did. Then I realized I could do everything I wanted to in the graphical window on one or more tracks at the same time. Works great.
RichieM
