Sagan Technology Metro • View topic - Recommended MIDI interfaces?
Postby Makyo » Tue Feb 11, 2003 11:18 pm
Hi,
I'm in the process of moving my music production --please don't laugh :roll:-- from an extremely stable Quadra to an iMAC and I'm wondering if anyone can recommend the best MIDI interface option for use with OS X and Metro . . .
Any advice would be greatly appreciated!
Gio
Makyo
Re: Recommended MIDI interfaces?
Postby Scoot » Tue Feb 11, 2003 11:51 pm
Well that depends on what else you want to be able to do with it.
You could get a simple midi interface or something like a Tascam US-428 USB Midi Controller which would give you audio inputs as well as midi in and out (I assume it would work with Metro as most other programs do).
Postby Guest » Wed Feb 12, 2003 1:37 am
I have a US-428 and find it works well with Metro in OS 9. I did some quick testing in OS X and things seemed to work there as well but that wasn't terrible aggressive testing.
Guest
Midi interface
Postby Gary K. Doty Sr. » Wed Feb 12, 2003 3:17 am
Hi Makyo,
I am using a Edirol UM-1 (1 in-1 out) and has worked fine for me under usb. I am using a eMAC G4 running Metro G4 6.0.4 build 1.
It has been working well for me.
Gary K. Doty Sr.
Gary K. Doty Sr.
Postby Jerm » Wed Feb 12, 2003 3:24 am
I have tested with a MOTU midi express XT and it seems to work real well. I have also tested with an Edirol UM880 with excellent results. These are both 8 in and 8 out MIDI devices.
Postby Achim » Thu Feb 13, 2003 3:00 am
I use a Midiman 4x4 - very reliable with OS 9 and OS X.
Achim
Postby françois » Sun Feb 16, 2003 3:24 pm
:lol:
i use emagic MT4 ( 2 in - 4 out ) and It's ok
Interfaces
Postby fastlanephil » Sun Feb 16, 2003 6:35 pm
I'm using a M-Audio Midiman 4*4 which always hookes up for me when I plug it in and a iMic from Griffin technology which works great for a simple in and out and has a switch for mic or line level input and supports 24 bit.
Midi interfaces
Postby Makyo » Wed Feb 19, 2003 11:21 am
Thanks for the replies!!!
Makyo
Midi Interface
Postby dannsh » Wed Feb 19, 2003 2:00 pm
I have a MOTU MTP AV on OSX. It is working just fine.
Danny
dannsh
Midi Interface
Postby vicpierce » Wed Feb 19, 2003 8:06 pm
My MOTU Fastlane (2in, 2out, thru) USB faultless under OSX.
vicpierce
