Sagan Technology Metro • View topic - Internal Port
Internal Port
Internal Port
Postby Marko » Mon May 31, 2004 7:52 am
In the popup menu for output ports I have only one port assigned to the internal synthesizer. (I have also 16 ports for my Edirol UA-20.)
In the online help I found some entries with "internal-1", "internal-2", unfortunately I cannot find such entries at the popup menu.
How can I get more than one internal channel?
Marko
(Metro SE 6.2, Mac OS X 10.2.8.)
Marko
Postby Jerm » Mon May 31, 2004 10:13 am
Go to the menu special->Modify-Instruments-and-busses and add up to 16 outputs on port internal.
Postby Marko » Mon May 31, 2004 12:47 pm
Works! Thanks!
Marko
