Sagan Technology Metro • View topic - How can I use a soundfont?
Postby sseaton » Mon Feb 24, 2003 2:14 pm
I want to try a soundfont with the demo. How do I get Metro to recognize soundfonts? Thanks.
sseaton
Postby buserror » Mon Feb 24, 2003 4:20 pm
You need to use the DLS output synthetizer; you then can select it as a MIDI device.
The DLS plugin allows you to choose the soundfont it will use to play. It selects by default the SoundFont present in your ~/Library/Audio/Sounds/Banks.
buserror
Postby Jerm » Mon Feb 24, 2003 6:07 pm
More info on using a soundfont can be found on the effects help page at:
http://www.sagantech.biz/metro/help/help5022.shtml
Postby sseaton » Wed Feb 26, 2003 1:46 pm
Thanks. I was able to use the soundfonts, although I don't understand how to use them with the Aux Busses. Does this have advantages over just puting them into the Library/Sound/Audio/Banks directory?
sseaton
Postby Jerm » Wed Feb 26, 2003 3:31 pm
sseaton wrote:Thanks. I was able to use the soundfonts, although I don't understand how to use them with the Aux Busses. Does this have advantages over just puting them into the Library/Sound/Audio/Banks directory?
I am not sure what you are asking.
The purpose of using the DLS/Soundfont plugin with Aux busses is so that you can have the effect global to all sections and not tied to any particular track. If you put the plugin on a track then muting/soloing and other operations may be unpredicatable. Also, on an aux buss, Metro will allow you to route all the outputs of the plugin. On a track you are limited to a single stereo out.
I believe the sound directory is unrelated.
