Sagan Technology Metro • View topic - "Smart Selecting" per MIDI channel
Postby buserror » Sat Feb 22, 2003 3:06 pm
When I import a MIDI 0 file, all the channels are grouped together into one track. Is there a way to select all notes for one MIDI channel, and make a new one track with only that one MIDI channel?
buserror
Postby Jerm » Sat Feb 22, 2003 3:08 pm
Yes. Use Expand by channel. This will put all channels on individual tracks. It is important to select the correct port of the track to expand so that you don't have to go back and change all the resultant tracks.
You could also use Extract Data (with the cut) option, to just extract a single channel of data.
