Metro manual definition - After Touch is the effect of holding down a key after it has been played. After Touch is sometimes referred to as pressure.
I would have thought pressure would be volume and volume is velocity? no?
What I don't understand is what is aftertouch doing?
Are soundfonts and quicktime instruments aftertouch aware?
I drew a few long notes and then went into the aftertouch display and drew lines/curves at maximum and minimum values.....before, during and at the end of notes. All the notes still sounds the same.
Pitchbend definitely works to change the note........how drastically does aftertouch affect the tone of the note?
Is my ear not picking the difference or is the tool not being used right?
scoot
