Sagan Technology Metro • View topic - No MIDI in OSX
No MIDI in OSX
No MIDI in OSX
Postby axnyslie » Sat Oct 04, 2003 8:41 pm
I'm trying to run Metro 6.0.8 on a G4 with OS X 10.2.8 with Audiophile 24/96 but I cannot make MIDI work. Everything works fine on OS 9.
In OS X MIDI Setup it scans and sees "Delta AP-MIDI" However this does not show up under the Ports option. Only "Internal" and "Analog 1/2 Delta-AP" so there is no option to record or palyback MIDI. All the projects I created in OS 9 cannot work either. The "Change Ports" window can not find a replacement.
Any Help would be appreciated.
axnyslie
Postby Scoot » Sun Oct 05, 2003 3:30 am
Is this the infamous 10.2.8 or the newer version which is now out?
As I'm unfamilar with the devices you mention, I was wondering if it could be a driver issue? Have you had it working in other OSX or Jaguar versions? Are the drivers the latest? Can you ask the makers if their products work in 10.2.8?
Postby axnyslie » Sun Oct 05, 2003 12:14 pm
It is the newer version of OS X 10.2.8 and Metro did not work with the previous OS X version either. So the issue isn't the OS version it's with the Metro version. The problem occured when I updated Metro to 6.0.8 and there is no updated driver from M-Audio for the Audiophile 2496.
axnyslie
Postby Jerm » Sun Oct 05, 2003 5:12 pm
It sounds to me like your AMS document is not configured properly. Have you gone through this:
http://sagantech.com/metroforum/viewtopic.php?t=352
Make sure you have devices connected to interfaces inputs and their receive channels are specified properly.
Postby axnyslie » Tue Oct 07, 2003 2:08 am
That didn't quite help either. It scans and finds "Delta-AP MIDI" I tried patching my Roland XP-30 to it but the drawn cable connections are always gone when I quit AMS. AMS has to stay open for the connection to work
axnyslie
Postby Jerm » Tue Oct 07, 2003 10:29 am
Have you contacted the device manufacturer? If AMS cannot hold a connection then Metro won't be able to either.
