Sagan Technology Metro • View topic - midi sync problems
midi sync problems
midi sync problems
Postby sigmasix » Sat Oct 04, 2003 10:52 am
i am trying to sync metro to my asr10 midi clock. so that metro syncs its record when i play sequences from the asr10. i have tried various settings but can't seem to get it right. it appears metro is recieving the time code as the tempo is jumping around equalling the asr tempo but metro does not want to record it. metro will sync its play but not its record.. does that make sense? anyone with any suggestions? thanks!
sigmasix
Postby Jerm » Sat Oct 04, 2003 1:34 pm
Did you turn on record tempo changes in the Record Criteria Dialog?
