Sagan Technology Metro • View topic - deleting time
deleting time
deleting time
Postby françois » Sat Sep 06, 2003 4:48 am
when I delete time in a song ( for example in a 100 measures song , 4 measures deleted between the 4th and 8th ) the song remains with 100 measures, and I have to delete them manually in the track window in the bars column
could you explain me how to do it more easely ?
Postby Scoot » Sat Sep 06, 2003 6:42 am
If you are using the delete time option from under the edit menu, it does shorten the length of the song in the tracks window.
Postby françois » Sat Sep 06, 2003 7:45 am
thanks scoot, I will try it again
