Sagan Technology Metro • View topic - When I drag in MIDI from Rapid Composer
Postby Stephan326 » Sat Feb 08, 2014 10:40 pm
When I drag in MIDI from Rapid Composer It places it at bar 6 instead of bar 1.
Stephan326
Re: When I drag in MIDI from Rapid Composer
Postby GSpro » Sun Feb 09, 2014 1:24 pm
Hi Stephan326,
I never heard of RC so, I googled it. Did you drag directly from RC into Metro, or you saved the midi file and then, opened it in Metro?
GSpro
Postby Jerm » Sun Feb 09, 2014 1:38 pm
I think there was an old bug that caused Metro to do that. You can either be sure you are using the latest version or use an edit command like shift or delete time after the drag.
Postby Stephan326 » Sun Feb 09, 2014 2:02 pm
I drag from RC.I am using the latest version of metro and rc.
Stephan326
Postby Jerm » Sun Feb 09, 2014 2:20 pm
Are you sure you are dragging to bar one? What is the Metro version number from the about box? What OS are you using?
Postby Jerm » Sun Feb 09, 2014 2:43 pm
It is also possible that the MIDI file has 6 measures of silence in it. If you want to be sure email me the .MID file for analysis.
Postby Stephan326 » Sun Feb 09, 2014 3:06 pm
When I drag that same file onto the desktop then in from desktop to metro it drops in at the 1.I don't get it.
Stephan326
Postby GSpro » Sun Feb 09, 2014 3:17 pm
Hello Stephan,
FWIW, I'm dragging midi files from ezdrummer and mdrummer and they all fall into place in Metro, that's without saving the midi file and then open it in Metro.
Adriano
GSpro
Postby Jerm » Sun Feb 09, 2014 4:30 pm
I could try installing the demo. Do you know if the demo of 'Rapid Composer' will let me do what you are doing?
Postby Jerm » Sun Feb 09, 2014 5:22 pm
I just tried it in Metro on the PC 32 bit and Metro LX PC 64 bit and it worked fine on both. Went to measure one.
Postby rubyatiy » Mon Jan 21, 2019 3:26 am
Stephan326 wrote:I drag from RC.I am using the latest version of metro and rc.
These was the type and hype from which you are not aware of this recently
rubyatiy
