Sagan Technology Metro • View topic - MIDI note length along the tempo
Postby TAUL » Sat Nov 10, 2012 3:31 am
Hello.
It seems that it is not reflected in the timing of MIDI "note off", when tempo is changed after "note on" signal of a long tone.
Are there some setting to crrect this state? :?
Thanks.
TAUL
Re: MIDI note length along the tempo
Postby Jerm » Sat Nov 10, 2012 1:21 pm
Hello Taul,
Can you post (or email me) a MIDI file that exhibits this problem?
Postby TAUL » Sat Nov 24, 2012 5:05 am
Thank you fast corresponding.
I've commented insufficient at this post. :|
This problem occurs with plug-in instruments.
That does not occur assigned internal sound.
I will mail you attach a sample data with problem.
Please test it.
Thank you.
TAUL
Postby Jerm » Sat Nov 24, 2012 1:35 pm
Ok thanks for the example.
This is a bug. The problem is that for softsynths (VSTi's) the note off time is calculated when the note on hits as it is noteOnTime+Duration. However this is incorrect since it is based on the tempo at the time of the noteOn.
I will look into fixing this as any workaround (to lengthen the notes randomly until they sound right) is extremely awkward.
Hopefully it will be fixed in time for Metro 7.0 release this year.
Postby Jerm » Sat Nov 24, 2012 5:23 pm
This is fixed in 7.0
Postby TAUL » Sat Nov 24, 2012 6:23 pm
Thank you for your "sonic" work! :shock:
That sounds great for me about Metro7. :D
Much thanks.
TAUL
