Has anyone experienced any issues with MIDI on Mac OS 10.5.5 (Leopard)?
I installed Metro 6.46 on my new Mac with Leopard, and have been totally unable to use MIDI. Audio is fine.
Interface is an emagic mt4. It appears as usual in AMS and in Metro's MIDI set-up dialogue.
Strange thing is MIDI in records data, but MIDI out does not trigger any sound playback. MIDI controller keyboard is also unable to play thru Metro on any assigned channels. (That is, no sound is played back. But if I hit record, the notes I play get recorded into Metro... )
Even stranger, running a test in AMS (Audio Midi Set-up) indicates MIDI activity in all four outs of the mt4, and not only that, the test out actually triggers sound in connected synths. But MIDI data from Metro cannot trigger sounds on assigned channels. Connected synths have LEDs that flash indicating MIDI activity, but no sound is produced.
The mt4 works fine if I plug it back into an old Mac running OS 10.3.
I suspected driver issues, but running a test with an m-audio firewire 410 also had the same problem -- no playback on MIDI Out from Metro's sequencer.
Obvious problems like bad cables, muted channels, wrong channel assignment, have already been ruled out.
If anyone has any idea what the problem may be, I'd greatly appreciate any advice or suggestions. I have never been this stumped by a MIDI problem in 15 years of working with it.
Also, if anyone has any recommended MIDI interfaces for use with Leopard & Metro, please pass them on. Thanks.
Also, I have heard there's a MIDI fix in the forthcoming 10.5.6 from Mac; did they break MIDI in 10.5.5? Anyone else having any problems?
