by Jerm » Fri Aug 11, 2006 1:16 pm
If it tests ok in AMS then you probably need to make sure that in Metro's MIDI Setup you have XP-30 selected in the record from popup.
Also, to see input you will need to select XP-30 as an output for track 1 in the tracks window and record-enable track 1.
