Sagan Technology Metro • View topic - Duplicate notes
Duplicate notes
Duplicate notes
Postby fastlanephil » Sun Jun 15, 2014 8:55 pm
Hello Jeremy,
I remember having this issue before but can't remember the solution or find it here with a search.
When I play in single notes or chords with my keyboard controller each note has another note underneath it when I drag the notes up or down in the Graphic Editor. I must be sending double data messages to Metro when recording.
Phil
Re: Duplicate notes
Postby Jerm » Sun Jun 15, 2014 10:00 pm
Most likely your keyboard is doing it. Can you check with a MIDI monitor program to see what the controller is sending?
You can easily delete them all in one fell swoop with the 'delete duplicates' command.
Re: Duplicate notes
Postby fastlanephil » Tue Jun 24, 2014 10:36 pm
Yes, I had two zones turned on the in the Kawai MP7 that were both sending external data.
Thanks Jeremy!
