by GSpro » Thu Jun 24, 2010 9:02 pm
Hello forum. Helo rickhaff.
I was using Drumtracks for a while too, but then I found MDrummer a month ago and I'm very, very happy with it.
I think it's an amazing plugin (AU/VST). It has sampled drum sounds and it can also output to midi (VST only), if you want to use the drum track in standard midi files. You can do anything with it. You really need to read about it.
Here is the link for more info and many video tutorials available on the site.
http://www.meldaproduction.com/mdrummer/
The developer is top notch too and will respond via email within minutes.
BTW, I'm not affiliated with Melda Productions in any ways. I'm just very satisfied with the product as much as I am with Metro.
Hope this helps
