Sagan Technology Metro • View topic - Naming regions
Naming regions
Naming regions
Postby Casper » Sat Nov 19, 2005 11:17 am
I wonder if I mis something, but it seems to me that I can not give a region a name. I have a project with a lot of regions in it and I have difficulties finding the right region for placing them in a different (right) order. If it is not possible already, this question should be in the feature request forum.
Casper
Postby Jerm » Sat Nov 19, 2005 12:44 pm
No it is not possible. You can color code the track but that is probably not what you want. Perhaps a feature request is in order here.
Postby Industro » Sun Nov 20, 2005 1:01 pm
Jerm wrote:No it is not possible. You can color code the track but that is probably not what you want. Perhaps a feature request is in order here.
How do you color code an audio track?
Industro
Postby Jerm » Sun Nov 20, 2005 5:30 pm
Double click on the region in the graphic editor. Then select the colored rectangle to change the track region color.
This may change soon so that each region within a track can have a unique color.
