Biffer wrote:Thanks Scoot. I guess where I'm still confused is where you say controll the volumn with the MAIN volumn fader. Does the individual volumn fader for each track no longer work when adding effects this way?
Biffer wrote:In other words, say I want to take down the volumn of the kick and leave the snare higher. I can't use the main for this but would need to use the individual volumn control.
Jerm wrote:Biffer wrote:Thanks Scoot. I guess where I'm still confused is where you say controll the volumn with the MAIN volumn fader. Does the individual volumn fader for each track no longer work when adding effects this way?
I think you are confusing 'Main' with 'Master'. In the right hand upper corner of the mixer window there is a popup that allows you to select the page currently displayed. Whereas the master fader is the one right most.Biffer wrote:In other words, say I want to take down the volumn of the kick and leave the snare higher. I can't use the main for this but would need to use the individual volumn control.
Assuming that the kick is on audio-1 and the snare is on audio-2, simply drag the audio-1 fader down in the main page.
Biffer wrote:However, on main page, when I drag the audio-1 fader down...some of the volumn goes but as long as the effects (aux) fader is up I can still hear the track (distantly). Shouldn't the sound completely disappear?
Users browsing this forum: No registered users and 24 guests
