Jerm wrote:You could try setting the Metronome to a MIDI device by opening the door in the transport.
jukehouse wrote:Earlier I could record with the Metronome Port set on INTERNAL if I had the Metronome turned on.
jukehouse wrote:Does any of this make sense ?
Jerm wrote:By "earlier" I assume you mean 6.1.
Jerm wrote:The important thing is that everything is recording fine now as long as the metronome setting is not internal. Yes? For example, you can now record fine even with the Metronome off. Right?
