Sagan Technology Metro • View topic - Routing Thru Aux Bus
Postby jukehouse » Fri Jan 14, 2005 8:05 am
Can anyone tell me how to route an audio channel in the mixer window (let's say a vocal) thru an Aux Bus channel in the mixer window (using 6.1). I've figured out how to create the Aux Bus and assign a VST effect to it but am stuck in trying to get my Audio track routed thru the Aux Bus.
jukehouse
Postby Jerm » Fri Jan 14, 2005 10:43 am
Juke,
Have you looked at scoot's aux setup tutorial?
Users browsing this forum: No registered users and 31 guests
