Sagan Technology Metro • View topic - 5 in 1
5 in 1
5 in 1
Postby Thor » Mon Aug 30, 2004 3:33 pm
How do I create sound motion from right to left, or towards a listener in Metro?
Thor
Postby Jerm » Mon Aug 30, 2004 6:12 pm
Thor,
If you are asking about surround, Metro does not do surround panning as of yet so you will have to do it manually by assigning outputs and panning. This is definitely not the easiest way to do surround sound.
5 to 1
Postby Thor » Fri Sep 03, 2004 7:37 am
Will z.matrix work with Metro to create surround sound?
Thor
Postby Jerm » Fri Sep 03, 2004 9:14 am
I am not directly familiar with z-matrix but it probably will not work very well. Metro currently also has a limitation of two audio inputs to any effects bus. This would effectively limit any surround sound panning plug-in's potential.
If you have a feature request we would be glad to see it in our feature request section of this forum.
