Scoot wrote:If you export audio and hit just export, the audio starts saving straight away. If you export using quicktime it preps it first and this can take a few minutes. What's it doing in this time and why does it do it?
Metro is creating a Quicktime Movie file since this is what Quicktime requires to do the conversion. This may involve merging all audio regions and could probably be optimized to take less time in the case where there is a single audio region.
Scoot wrote:Why does metro saving out as a MP3 take so long compared to itunes?
Are they using different engines?
Metro does not do the conversion. The conversion to MP3 is done by the LAME audio engine and so why it takes so long would be a question better posed to the developers of that engine.
http://lame.sourceforge.net/ Since it is open source, you could theoretically look at the code and make it faster.
Scoot wrote:If I can see .ogg files in the jukebox, but can't do anything with them, are they in some PC format or strange format.......or is something required to get them to play?
I do not understand. Metro reads and writes .ogg files, so you can do something with them in Metro. They are cross platform files.
